(Pekko @ Heinä. 20 2004,11:23) kirjoitti
C - SENSITIVITY ADJUSTING :
1. Press button (A) and (B), DO NOT release until you hear audio-alarm ringring long twice.
Then press button (A) again to adjust the sensitivity.
2. Press button (A) to low down 1 degree each time
(circulate adjusting from 1 degree to 8 degrees)
3. When you are adjusted, you will hear audio-alarm once at 1 degree. The audio-alarm will
ring short once when the degree are from 2 to 8 degrees.
4. As long as you have'got the sensitivity you want, press button (B) to make it done.
D AUDIO-ALARM LENGTH ADJUSTING:
1. Press button (A) and (B) DO NOT release until you hear the audio-alarm ringing long
twice. Then press button (D) again to adiust the alarm length,
2. Press button (D) to adjust 2 second shorter of the alarm length each time (30 to 16 seconds
circulate adjusting ).
3. When you are adjusting, you will hear audio-alarm ringing long once at 30 seconds of the
alarm length and the audio-alarm will ring short once when the alarm length are from 29
to 16 seconds.
4. As long as you have got the alarm length you want, press button (B) to make it done.
