Changes made from version 3.30 to 3.80:
Add support for African Time zones.
Add support for several new pre-recorded voices.
Add support for distances in yards when a British voice is selected (may require updated voice).
Added support for MAD Maps scenic routes.
Allow the compass page to display 5 digits of elevation.
Improved handling of circular routes. Allows entry at alternate point. Will not announce arrival when starting a route. (All routes will be deleted after update, but can be re-imported from GPX files.)
Keep the map detail level when go from main map to browse map.
When reviewing a gas station after pressing the fuel button from main map, the map will now be centered on selected gas station rather than the vehicle.
Change Optimal Reorder so it does not include the final point when reordering.
Correct issue where backlight may change if you remain on the backlight adjust page for a period of time.
Correct issue where backlight may turn off when location is above polar circle.
Correct issue that would sometimes cause highways to be labeled with the incorrect name.
Correct issue that would not allow more than a single point to be added to some routes.
Correct issues when the same map is loaded in two different regions.
Correct issue when searching for cities on basemap.
Correct off road transitions in track to route when there is no map coverage.
Correct issue playing Audible format 4 books.
Correct distance for mixed routes imported from MapSource
Correct issue that caused all traffic delays to be 1min when using certain maps.
Correct issue that prevented TrafficMaster service from being properly named on the unit.
Correct issue that prevented some very large track log activities from being archived correctly.
Correct issue where changes to a route would be lost if you press and hold the back button.
Correct issue that caused MP3?s to be paused for navigation announcements when navigation was set to off and a pre-recorded voice was selected.
550:n päivitys:
http://www8.garmin.com/support/downl...ls.jsp?id=1907
