Kuinkas huomiovaloista on säädetty laissa? Millaiset lisävalot voit asentaa mopoosi näkyvyytesi parantamiseksi pitkien valojen käyttämisen sijaan?
Anteeksi vähän pitkä vastaus, mutta kun tämä tuntuu aina välillä herättävän kysymyksiä, niin laitetaan vähän perusteellisempi lainaus voimassa olevasta direktiivistä:
DAYTIME RUNNING LAMP
6.13.1.
Presence
Optional for motorcycles.
6.13.2.
Number
One or two of approved type according to Regulation No. 87.
6.13.3.
Arrangement
No special requirement.
6.13.4.
Position
6.13.4.1.
In width:
6.13.4.1.1.
An independent daytime running lamp may be installed above, below or to one side
of another front lamp: If these lamps are one above the other, the reference centre of
the daytime running lamp shall be located within the medium longitudinal plane of
the vehicle; if these lamps are side by side, the edge of the illuminating surface shall
not be more than 250 mm from the median longitudinal plane of the vehicle.
6.13.4.1.2.
A daytime running lamp, that is reciprocally incorporated with another front lamp
(driving beam headlamp or front position lamp), shall be fitted in such a way that the
edge of the illuminated surface lies not more than 250 mm from the median
6.13.4.1.3.
Two daytime running lamps, of which either one or both are reciprocally
incorporated with another front lamp, shall be installed in such a way that their
reference centres are symmetrical in relation to the median longitudinal plane of the
vehicle.
E/ECE/324
} Rev.1/Add.52/Rev.2/Amend.2
E/ECE/TRANS/505
Regulation No. 53
page 6
6.13.4.1.4.
In the case of two daytime running lamps, the distance separating the illuminating
surfaces shall not exceed 240 mm.
6.13.4.2.
In height:
Above the ground not less than 250 mm and not more than 1,500 mm.
6.13.4.3.
In length:
At the front of the vehicle.
6.13.5.
Geometric visibility
Horizontal: Outwards 20° and inwards 10°.
Vertical: Upwards 10° and downwards 10°.
6.13.6.
Orientation
Towards the front. The lamp(s) may move in line with the steering angle.
6.13.7.
Electrical connections
6.13.7.1.
If installed, the daytime running lamp shall be switched ON automatically when the
device, which starts and/or stops the engine, is in a position which makes it possible
for the engine to operate.
The daytime running lamp shall switch OFF automatically when the headlamps are
switched ON, except when the latter are used to give intermittent luminous warnings
at short intervals.
Furthermore, the lamps referred to in paragraph 5.10. shall not switched ON when
the daytime running lamps are switched ON.
6.13.7.2.
If the distance between the front direction-indicator lamp and the daytime running
lamp is equal or less than 40 mm, the electrical connections of the daytime running
lamp on the relevant side of the vehicle may be such that either:
(a)
It is switched OFF; or
(b)
Its luminous intensity is reduced during the entire period (both ON and OFF
cycle) of activation of a front direction-indicator lamp.
6.13.7.3.
If a direction indicator lamp is reciprocally incorporated with a daytime running
lamp, the electrical connections of the daytime running lamp on the relevant side of
the vehicle shall be such that the daytime running lamp is switched OFF during the
entire period (both ON and OFF cycle) of activation of the direction-indicator lamp.
Voiko sitä enää tämän selkeemmin sanoa...
Päiväajovalot LAMP
6.13.1.
Läsnäolo
Valinnainen moottoripyöriin.
6.13.2.
Numero
Yksi tai kaksi hyväksytyn tyypin mukaan asetuksen nro 87.
6.13.3.
Järjestely
Ei erityisiä vaatimuksia.
6.13.4.
Leveyssuunnassa:
6.13.4.1.1.
Riippumaton huomiovalaisin valaisin voidaan asentaa yläpuolelle, alapuolelle tai sivuun
Toisen ajovalot: Jos nämä valaisimet ovat päällekkäin, vertailupisteeseen
huomiovalaisin lamppu on sijoitettava keskipitkän pituussuuntaisen tason
ajoneuvo, jos valaisimet ovat vierekkäin, reuna valaisevan pinnan on
olla korkeintaan 250 mm pitkittäisen ajoneuvon.
6.13.4.1.2.
Huomiovalaisin lamppu, joka on rakenteellisesti yhdistetty toiseen ajovalot
(Kaukovalon tuottavan ajovalaisimen tai etuvalaisimesta), on asennettava siten, että
reuna valaistu pinta sijaitsee enintään 250 mm keskiviivan
pitkittäistason ajoneuvon.
6.13.4.1.3.
Kaksi huomiovalaisimet, joista toinen tai molemmat ovat rakenteellisesti
yhdistetty toinen etu-lamppu, on asennettu siten, että niiden
osaamiskeskusten ovat symmetrisesti suhteessa pituussuuntaiseen keskitasoon
ajoneuvoon.
E/ECE/324
E/ECE/TRANS/505
Asetus nro 53
Sivu 6
6.13.4.1.4.
Kun kyseessä on kaksi huomiovalaisimet, etäisyys valaisevien
pinnat eivät saa olla enintään 240 mm.
6.13.4.2.
Korkeussuunnassa:
Maanpinnan yläpuolella ei ole pienempi kuin 250 mm eikä suurempi kuin 1500 mm.
6.13.4.3.
Pituussuunnassa:
At ajoneuvon edessä.
6.13.5.
Geometrinen näkyvyys
Vaakasuora: ulospäin 20 ° ja sisäänpäin 10 °.
Vertical: ylöspäin 10 ° ja alaspäin 10 °.
6.13.6.
Suunta
Eteenpäin. Lamppu (t) voi liikkua mukaisesti ohjauskulman.
6.13.7.
Sähkökytkennät
6.13.7.1.
Jos asennettu, huomiovalot lamppu on kytketty päälle automaattisesti, kun
Laite, joka alkaa ja / tai pysäyttää moottori, on sellaisessa asennossa, joka tekee mahdolliseksi
ja moottorin toiminnan.
Huomiovalaisin lamppu on sammuvat automaattisesti, kun ajovalot ovat
kytketään päälle, paitsi jos jälkimmäisiä käytetään antamaan ajoittainen valoisa varoituksia
lyhyin väliajoin.
Lisäksi lamput kohdassa 5.10. ei saa kytkeä päälle
huomiovalaisimet on kytketty päälle.
6.13.7.2.
Jos etäisyys etuosan suuntaan-merkkivalo ja Huomiovalaisimien
Lamppu on yhtä suuri tai pienempi kuin 40 mm, sähköliitännät ja huomiovalot
valaisin asiaan puolelle voi olla sellainen, että joko:
(A)
Se kytketään pois päältä, tai
(B)
Sen valovoima on vähennetty koko ajan (ja sen ulkopuolella
sykli), aktivoi etuosan suuntaan-merkkivalosta.
6.13.7.3.
Jos suuntavalaisin on rakenteellisesti yhdistetty päiväajovalot
lamppu, sähkökytkennöissä huomiovalot valaisin asiaan puolella
Ajoneuvon on oltava sellainen, että huomiovalot valo kytketään pois käytöstä
koko ajan (ja sen ulkopuolella sykli) aktivoinnin suunnan-merkkivalo.
No tuohan on ihan selvä ja käsitelty asia.
Eli huomiovalot on sama asia kuin daytime running lamps eli päivävalot. Eivät siis saa palaa yhtäaikaa ajovalon kanssa?
Ajatus aiheesta tuli eilen radiosta, jossa poliisilla olisi päivävalot peileissä, jos kuulin oikein.
Mulla ainakin saa lisävalot palamaan pelkästään lyhyiden valojen kanssa. Sammuvat automaattisesti, kun vaihtaa pitkille.
